Gearing quetion on ...
[Closed] Gearing quetion on 1 x 11
12 Users
I'm going to convert my 2014 Giant Anthem to 1 x 11. I have found a good deal on Shimano SLX 11-46 cassette and am really unsure whether to go 32T or 34T up front. I want it to be as near to current 3x9 set up (24/30/40 and 11/36 cassette). I ride long cross country routes which long road sections.
so 32T or 34T ...? thanks
Posted : 22/07/2019 9:07 pm
If you do a lot of road sections you’ll spin the 32/11 combo out really easily.
What you need to do is go onto Sheldon brown’s gear calculator and see how 34/46 compares to the low gears you have now. Do you use 24/36 a lot for example?
Posted : 22/07/2019 9:17 pm
 nuke
^^^beaten to it...this is advice i was going to give; have a play around on Sheldons gear calc
Posted : 22/07/2019 9:24 pm
You'll lose gears at the bottom and top end whichever one of those chainrings you go with. If speed on the road is key to you then go with a larger one, if you do lots of climbing ten you may be better off with a smaller one. If both are important then stick with the triple or go with a double.
Posted : 22/07/2019 9:29 pm
My first mountain bike (well, the first I started considering gears on) was 12-28 and 28-38-48.
So that would be similar to the cassette you mention with a 44/46 chain ring.
What's more important to you, climbing gear or spinning along the road gears?
Posted : 22/07/2019 9:54 pm
I don't think 1x 11 is going to give you a big enough gear range . I would go 1x12 with a 10-50 cassette or go to a 2x10 or 2x11 which will give you a good range of gears and be better than 3x9 .
Posted : 22/07/2019 10:36 pm
I run an 11-50 Sunrace cassette with a standard Shimano XT derailleur. No extras required and no trickier to set up than the 11-42 it replaced. Iirc the Shimano cassettes have big gaps in the low gears.
Posted : 22/07/2019 10:49 pm
If you go for a cassette with a small cog of 10T then you'll also need a new freehub as it's highly unlikely to fit your current one. Depending on the make of your existing hub it might mean a simple replacement or a new hub and rebuild or a new wheel.
I went from the old "standard" 3x9 on a 26" wheeled bike to 1x10 on a 29er and lost a total of three ratios, in my case I went for one at the bottom end and two at the top. This was before wide range cassettes so it was standard cassette plus extender cog. I'll use either a 30T or a 32T chainring.
It took a few months to get completely comfortable with the "lack" of gears but now it's rare that I use the lowest gear (or the highest). Most of my riding is in the Dales so there's a mix of fast tracks, big hills and roads. I'll spin out on the road at about 40kmh but it's not something I can sustain for ten or fifteen minutes so it's not really a problem. By the time I'm running out of gears at the bottom end I'm on terrain that I'd be walking no matter what gearing I used.
Posted : 23/07/2019 8:11 am
Spinning out on the road isn't ever a consideration for me on a mountain bike.
If it is, buy a gravel bike.
Posted : 23/07/2019 8:14 am
http://ritzelrechner.de/
Allows you to compare two setups side by side.
You'll need 32 to get within touching distance of your easiest gear, and you'll lose a couple of gears for higher speed riding even with a 34, so it depends which compromise you think you can make.
Posted : 23/07/2019 8:47 am
OP what size wheels do you run? I had a 29er converted a few years ago and ran 10 speed with a 30tooth chainring and a 11-40 cassette, didnt have any issues at the time. I have a diff 29er now and run 28tooth chainring with a 10-42 cassette.
The new 29er is heavier than the last and when being lazy the 42 gets more use than it should. I do feel occasionally when at bike parks like I could do with a higher/harder gear but the high speeds of bike parks dont reflect the terrain I ride regular.
Posted : 23/07/2019 8:53 am
What about 2×9 34-50 +11-40...converted a cx comp as a daily runner(with sunrace 11-40 9 speed casette.. only added a few links in the chain.. Its slightly too short(only a smudge) haven't had problems going fast and no hill it can't get up..
Downdsides are gappy gears and 34-11 feels like 50-40..so not such a large gap in chainrings..
No chain dropping but good gear range..and really cheap.. Cost less then £100. Took 1 hour to install.
Posted : 23/07/2019 9:59 am
