Gear set up help if...
[Closed] Gear set up help if you will!
4 Users
Evening,
Just finished building my fs frame up, set the gears up in the stand, worked fine, set the shock up to my weight, and went for a spin. The rear mech was shifting under my weight, which is a new one on me. What do i have to do differently to the hardtails I'm used to?
Cheers,
Tom
Posted : 27/05/2011 7:28 pm
gear cable too short so as the sus moves it pulls the cable
Posted : 27/05/2011 7:29 pm
that would be my guess as well or it catching on a moving suspension part/pivot doing the same.Possibly poor indexing needs a little fettling?
Posted : 27/05/2011 7:34 pm
Cheers TJ, would that just be the inner, or both that are too short?
Edit: Indexing was fine in the stand, shifted up and down perfec'like.
Posted : 27/05/2011 7:35 pm
The outer will be too short but that in turn means the inner will also be too short.
Posted : 27/05/2011 7:46 pm
Spot on all, it's not a single outer, and the bit of the outer that goes from main to rear triangle was run like i was setting up my hardtail. Stuck another bit there, with about 8cm or so extra length, and it's shifting like a dream.
Cheers guys!
Posted : 27/05/2011 8:04 pm
