Gear ratio for SSCX
[Closed] Gear ratio for SSCX
6 Users
I’d like to play in a few CX races this year and with minimal investment will use my Charge Grinduro.
It currently has a 44t chain ring with 18T SS freewheel.   This is likely to be tough to race in small muddy races, so what ratio freewheel would be best?
And, am I right to change the freewheel (its an expensive one beginning with B cant remember the rest) to protect the current one?
Thanks
Posted : 05/06/2018 10:51 am
57" gear works for me. Used to be 38x18 now on 40x19.
Posted : 05/06/2018 10:54 am
 JoB
i use 38/18 too which i've found a good gear for both mucking about and racing over the years, your mileage/legs/fitness may vary
it can be easier to change a chainring than a screw-on freehwheel 🙂
Posted : 05/06/2018 11:06 am
I think I used 40x18 for my SSCX expeditions earlier in the year. I ended up being a tiny bit overgeared through the Koksijde sand dunes, but it was about right for the typical UK course.
Posted : 05/06/2018 11:40 am
It can be very course and season dependent. At the final melting snow mud swamp of a race I was worried 36:17 would be too low (and even that turned out to be too high).
If you want to do ratio swaps then try and work in jumps that total 4 teeth = 1 chain link more / less so that you don't have to make major moves of wheel and brakes. Can also run the same main chain with two split links and have a selection of different length chain offcuts to join between them.
Posted : 05/06/2018 12:24 pm
Great thanks, I think I'll try 38/18 and see how it goes.
I think thats a standard 5 bolt chain ring on there ( http://www.wiggle.co.uk/charge-plug-grinduro-single-speed-adventure-road-bike/), so that and a pair of Baby Limus set up tubeless should do.
Posted : 05/06/2018 6:24 pm
I only race myself but I run 36:17 on my fixed gear (59GI) and find it perfect for fire roads and easy single track.
I top out downhill at around 35mph and get can up every hill in my area while cursing along at 18mph on flattish stuff.
Posted : 05/06/2018 7:15 pm
