Garmin went in the ...
[Closed] Garmin went in the wash!
10 Users
My wife just noticed my Garmin pressed against the inside of the washing machine door whilst it was 20 minutes into a cycle. I quickly drained the machine and put the Garmin in a bag on rice.
What are the chances of it working when I try to switch it on? I can't be the only person who has done this.
Posted : 31/08/2018 10:29 am
It'll probably work - they're pretty robust things and already quite waterproof. Just don't microwave it!
Posted : 31/08/2018 10:39 am
I put my Oakley through the washing machine a while back. Ruined the lenses
Posted : 31/08/2018 11:06 am
Hoping you left it on so we can see the stats!
(sorry!)
Posted : 31/08/2018 11:12 am
As mentioned in a previous thread my Vivoactive HR died in a hot tub. Despite being over year out of warranty they have agreed to replace it free.
Posted : 31/08/2018 11:25 am
A lot of electronic devices fail because they're switched on when they get wet. Garmins are pretty robust and I wouldn't be surprised if it works as normal. Since they're waterproof though, might be a good idea to open it up (if you can) to let any water out?
That said, I guess it depends what heat you had it on.
Posted : 31/08/2018 11:27 am
I put my Garmin 20 through the wash, still working a year later. It was off though.
Posted : 31/08/2018 11:54 am
Depending on the model, your altitude might be a bit squiffy for a while!
Posted : 31/08/2018 11:56 am
Come to think of it my old Edge 305 or whatever model number it was went through loads of times, left it to dry and worked fine.
Posted : 31/08/2018 11:57 am
My Garmin went through the wash for a full duration. It still worked except it would no longer talk to the computer when plugged in. So i just use it for map navigation rather than loading routes and following them.
Good luck!
Posted : 31/08/2018 12:02 pm
Lost my 510 in a mudddy puddle for the best part of an hour last winter (switched on) and it's still fine.
(Branch snapbakc from the rider in front took it off, I didn't notice until further along, guessed where it had happened and went back eventually found it by draining a fairly deep puddle).
Posted : 31/08/2018 12:11 pm
