Garmin quarter turn...
[Closed] Garmin quarter turn top tube mount?
6 Users
I was looking to mount my Garmin edge on the top tube of my Rallon. The tubes are too thick to mount with the supplied bands and it seems a bit unsatisfactory. You can get a mount that fits on the knock block for Treks but I was thinking a female mount with an adhesive pad. I could have sworn I'd seen one before but can't find anything on looking at the moment.
Has anyone come across anything like this?
Posted : 09/08/2020 2:32 pm
https://www.76projects.com/shop/enduromount
One of them?
Posted : 09/08/2020 2:37 pm
I have one of those ^ and would highly recommend. For some reason you can only twist one way but I have nearly got used to that😀
Posted : 09/08/2020 2:48 pm
That's the puppy it didn't come up in searches but that should do the job just fine.
Posted : 09/08/2020 3:04 pm
Get longer bands?
Posted : 09/08/2020 5:54 pm
Just make sure you can rotate the bars and brake levers if it doesn't clear then you will end up ripping it off in the first crash.
Posted : 09/08/2020 8:21 pm
Get longer bands?
Doesn’t always work depending on the frame. E.g.I’d have to wrap them round both the top and down tubes to try and make that work
Posted : 09/08/2020 8:50 pm
