Garmin HR strap dea...
[Closed] Garmin HR strap dead.
11 Users
Have tried a battery change to no avail. Any other suggestions before I write it off and buy a new one?
Posted : 21/08/2014 5:56 pm
Wetted the contact points before strapping it on (oo-er 😀 ) / given it a clean?
I think it doesn't power up to be detected until it's got a complete circuit, i.e. strapped on your body and good contacts.
Posted : 21/08/2014 6:08 pm
Usually, it's working by the time I've got on the bike; if not, the sweat usually sorts the contact issue (as an aside, someone was selling conductive gel for HR straps a while back, which sounded a) unpleasant, and b) not really necessary).
Posted : 21/08/2014 6:16 pm
Maybe this?...
"Both the Premium Heart Rate Monitor and the standard Heart Rate Monitor utilize a CR2032 battery. If a battery is placed in the device too soon after the old battery is removed, it can cause the accessory to experience a power overload causing the device to fail to operate."
https://support.garmin.com/support/searchSupport/case.faces?caseId=%7Bd320e3a0-0a6b-11de-76c5-000000000000%7D
Another shoddy bit of Garmin engineering if it can be trashed just by swapping a battery over too quick!
Also see [url= http://www.koelnerwasser.de/?p=325 ]How to get the Garmin heart rate monitor to work after a Battery change[/url]
Posted : 21/08/2014 6:40 pm
Probably the strap is worn out.
Happened to mine after about 12 months of use - contacts go leading to erratic readings (tried new battery etc).
Buy a Polar elastic strap much better quality and cheaper than a Garmin one - it's what I did and heart rate reading were back to being consistent.
This is the one that the Garmin hrm pod will clip onto
[url= http://www.wiggle.co.uk/polar-spare-elastic-soft-strap/ ]http://www.wiggle.co.uk/polar-spare-elastic-soft-strap/[/url]
Posted : 21/08/2014 6:47 pm
Yep my Garmin strap went after 6 months. If it's the new type with the removable transmitter just replace it with the Polar strap.
Posted : 21/08/2014 6:51 pm
^^ what makes the polar better? seen it mentioned a few times, went out day before yesterday and mine (Garmin) was showing 195bpm from the off, newest model, circa 6 months old
Posted : 21/08/2014 6:55 pm
What forester says. Get the polar strap it's miles better. My garmin strap even with a new battery would spike upto 230bpm's when I would expect to be around 140. Swapped to the polar strap with the garmin clip in transmitter bit and had no issues at all.
Posted : 21/08/2014 7:26 pm
Polar seems to better quality + more durable. My Polar strap has not missed a beat for the last 12 months (with the Garmin pod). I should also add that the Polar elastic strap gets washed at 30 degrees in the washing machine every week.
Plus whatever for buying the Polar strap.
Posted : 21/08/2014 7:34 pm
Give Garmin UK a call, and see what they say.
Phone (freephone from UK landline): 0808 238 0000
Phone (within UK): 0870 850 1242
Phone (outside UK): +44 870 850 1242
Posted : 21/08/2014 7:37 pm
Put the battery in upside down for ten seconds. Sort of an ultra reset on Garmin HRMs. Won't damage it.
Posted : 21/08/2014 8:19 pm
It's the old style one.
Posted : 21/08/2014 8:44 pm
Putting the battery in upside down sorted it for me when mine stopped working.
Posted : 21/08/2014 9:13 pm
Mine stopped working a little while back. I'd had it for around 6 months, tried everything you suggested to fix the problem with no luck.
Called Garmin and they immediately offered to send a replacement which arrived 3 days after the phone call was made.
Posted : 22/08/2014 5:47 am
 DanW
Is it the soft version? Mine died after a few months and they are known to be a bit shoddy. Garmin replaced it for me under warranty where I requested the hard strap version which has since been faultless for 2 years. Garmin soft straps have known issues and the cure is either a hard strap or more durable Polar strap. If you have problems with the hard strap then I guess sending it back to Garmin is the best option and you've just been unlucky. I always put a few drops of water on the contacts before use BTW as it doesn't always work "dry"- have you tried this too?
Posted : 22/08/2014 9:00 am
Yep, tried that.
As it's the hard strap and (it transpires from finding the order) five years old, I think it's time to cut my losses and buy a new one. Is the Polar strap definitely ANT+ compatible? I thought they used their own wireless protocol?
Posted : 22/08/2014 9:07 am
Unfortunately no.
If you can get another Garmin hard strap. If not you'll have to bite the bullet and get the Garmin soft strap + ANT+ transmitter and be prepared for it to fail and then splash out on the polar strap which you connect the Garmin transmitter to.
Last time I looked there were very few alternative Ant+ HRM options. YMMV.
Posted : 22/08/2014 9:12 am
 DanW
I think the idea is that you would use the Polar strap and Garmin transmitter. Since you don't have the soft strap Garmin version this is kind of pointless- perhaps you're better off buying a new Garmin hard strap? 5 years use isn't bad going and most people seem to like the hard strap Garmin one from a durability point of view
Posted : 22/08/2014 9:13 am
Ah - I see - it's the [i]strap[/i] rather than the HR sensor that's the problem with the Garmin one?
Ah - I see - it's the strap rather than the HR sensor that's the problem with the Garmin one?
With the newer soft strap yes.
Posted : 22/08/2014 9:17 am
I've found [url= http://www.dcrainmaker.com/2010/08/solution-to-heart-rate-dropoutsspikes.html ]this[/url] on the ever GPS-geeky DC Rainmaker which explains all.
Posted : 22/08/2014 9:34 am
