Garmin Forerunner 3...
[Closed] Garmin Forerunner 35 - strap issues
5 Users
I have the forerunner 35 which I use for an everyday watch, but more importantly for recording rides (and the very occasional run). However, if I wear it for more than a few days I inevitably get very bad rash/soreness akin almost to a burn.
anyone else have this issue and found a way to cure it? I think it’s worse when I get wet but never had this with other watches. Looking for aftermarket straps but only appear to be other silicon straps, so not convinced I won’t just encounter the same issue (unless someone tells me different). I’d prefer a rubber or even leather strap but can’t see any.
Shame as I don’t want to retire it (found the watch to be spot on for what I want) but similarly don’t want a red and inflamed wrist!
Posted : 15/07/2018 1:16 pm
Daft question, but do you wear it overly tight?
I had the same problem with mine when I first bought it assuming it had to be tight to get a decent HR reading, loosened it off and no problems since.
Posted : 15/07/2018 1:32 pm
Not a silly question at all...but I do wear it quite loose. The strap has so many holes you can adjust it to three or four positions and still be comfortable. However even when wearing it quite loosely I still get the issue.
Posted : 15/07/2018 2:21 pm
I have the Foreunner 235HR and the original strap was a bit awkward feeling, maybe a bit too rigid? but my ebay £4.50 replacement strap is a lot softer and much more comfortable. No problems at all for me.
Posted : 15/07/2018 2:32 pm
I had the same issue but couldn’t solve it. I tried wearing it looser etc. Would take it of during the day whilst at work to minimise wear but nothing worked. Ended up selling it on I am afraid. Sorry to not offer more help!
Posted : 15/07/2018 3:19 pm
Robbo that sounds familiar!
Posted : 15/07/2018 3:30 pm
Same happened here when I first had it. As said, seemed worse when moisture got behind it. Seems to have cleared up now though and had no problems for a while so maybe worth giving it a bit longer?
Posted : 15/07/2018 3:34 pm
