Garmin Etrex 3, occ...
[Closed] Garmin Etrex 3, occassional movement when static
7 Users
 PJay
I've got a new Garmin ETrex 3 which I'm really impressed with. I have noticed one anomaly though. On occasion, when the unit is static it does register movement for a few seconds. I haven't have a chance to take it out on the bike yet, so these observations have been indoors with variable satellite reception and a variety of things might be affecting reception and positioning.
I just wondered whether this is anything to worry about; I believe that some drift is normal as, even with perfect reception, an absolutely precise position isn't held (the Garmin website lists a range of effects that can degrade accuracy).
Posted : 01/01/2014 7:29 am
Completely normal.
Posted : 01/01/2014 7:41 am
That used to be caused by the random error that the US built into the civilian system to deliberately degrade the accuracy slightly.
Posted : 01/01/2014 8:10 am
What rockhopper is talking about is called selective availability, it have 100 or so meter offsets in position, but it was switched off a while ago- what you are seeing especially indoors is the effects of multi-path on the signals most likely. But don't worry, Tis completely normal.
Posted : 01/01/2014 9:33 am
Turned off 14 years ago...
Posted : 01/01/2014 9:47 am
Unless you get a Differential GPS, or a Military P code set, all GPS units will show some movement.
Since SA was switched off you can expect about 5 - 10 m accuracy.
Check the "HDOP" and "VDOP" values, the lower the DOP the better the precision. HDOp is the more important.
[url= http://en.wikipedia.org/wiki/Dilution_of_precision_(GPS) ]DOPs[/url]
If you are sad like me then you may find this interesting [url= http://www.kowoma.de/en/gps/errors.htm ]GPS errors[/url]
Posted : 01/01/2014 11:16 am
I used to sell GPS but that was 20 years ago now! I didn't know SA had been turned off.
Posted : 01/01/2014 11:21 am
 PJay
Thanks for the info. it's good to know that it's not faulty; it's a fantastic piece of kit for the money and it'll take a while to get to know.
Posted : 01/01/2014 6:34 pm
think it was bill clinton. we should thank or maybe monica lewinski 😉
Posted : 01/01/2014 9:38 pm
