Garmin Edge Touring...
[Closed] Garmin Edge Touring - grid reference
5 Users
I can't find any way to get a grid reference out of my Edge Touring. This has always been easy enough on Etrex models and I'm sure on the old Edges. Am I missing something?
Sometimes it's very useful to be able to pinpoint yourself on an OS map.
(note - grid reference included in features on these lists -
https://thebikecompany.co.uk/bike-accessories/garmin-edge-touring-gps-enabled-cycle-computer/
http://www.edinburghbicycle.com/products/garmin-edge-touring)
Posted : 19/07/2016 10:43 am
On my Edge 810 it's > Spanner > System > Units > Position Format (British Grid).
Not sure if it's the same for Touring.
Posted : 19/07/2016 10:50 am
does it support connect IQ apps? there are some widgets that'll do it.
Doesn't look like it support apps.
that's a start - yes, can set the "Position format" to British Grid. Can't find any screen that displays it though.....
Posted : 19/07/2016 10:54 am
I've a touring (and an edge 25) - always wondered why there isn't a quick function for this to provide EM services with a grid ref if the worst happens.
Posted : 19/07/2016 11:47 am
If you click on the map you can drop a pin on the spot you want. Can't remember if that gives you the grid ref or can be configured too. Will update later if no one else has
Posted : 19/07/2016 12:00 pm
Have you tried Spanner > GPS > Mark Location > Tick > Change Location (will show the BNG 10 figure grid ref).
Posted : 19/07/2016 12:02 pm
Ok - that's it.
Drop a pin - it give sit a name and distance from current location at the top of the map screen. Touch that info and it brings up the elevation, distance and Grid Ref.
Touch the navigation hand, touch your location (the little pyramid) and it saves that location (and you can get the grid ref by touching it again).
Not very convenient - gives you loads of useless points on your mapping
Posted : 19/07/2016 12:10 pm
