Ride this morning, powered it up and then it died about 5 seconds after power up. Wouldn't switch back on so just thought I'd left it on so killed the battery.
Rode without it, got home, plugged it in - powered up and showed 100% - little odd!
Done a hard reset and now showing 73% (which is about what I was expecting as 78% after last ride). Plugged it into mains and its now not budging off 73%.
Tried USB plug, computer and 2 cables, no change!!
Any ideas? Circuit? Battery? Firmware?
Short of taking it apart I'm out of ideas!!
Does the computer recognise it when plugged in? If not then it could be water getting into the USB port.
Yep tried that - registers its charging and registers as a device, lets me write and delete stuff from it no issues!
I've left it charging and its actually now started to creep up - maybe i'm impatient, maybe a glitch - probably needs a a while to see if I can replicate the fault again!
