Pretty much as the tile. It seems to happen most often within a few mins of first turning it on, but can happen at any time.
Did a ride tonight, about an hour and it happened 3 times!
Battery is fine and pretty full charge and I am sure I have not pressed the button by mistake
Has anyone else had the same problem? Is there a fix?
Thanks!
its the USB port rubber getting squashed - this connects the battery to the unit.
you need to split it - and youll see the rubber round the USB port - cut another out of an innertube and fit the two - this will provide a constant contact.
Does it make any difference that I have lost the rubber blanking piece to cover the USB port?
nope
its the act of pushing the usb in when you get to the computer
my 205 was the same , worked fine after the above fix TILL i dropped it shutting the garage door and smashed the screen.
its a common fault
Just tried this on my 705 that died a few month ago, garmin said it was goosed and would exchange for £100.. It now works fine...cheers Trail rat .... 8)
fyi a little clear silicone works for sticking the 2 halfs together - just use zip ties to hold it till it sets
