Garmin chest strap
[Closed] Garmin chest strap
9 Users
 2002
I have been using the Garmin Soft chest strap with my Edge 800 and the heart rate strap may be about 2 years old now and it seems to be playing up a lot now. Is the later strap ok or is there another make worth trying out.
Posted : 05/10/2014 6:12 pm
Later strap seems fine - I had the same. Check the version number on the sensor as well as it's slightly different.
Posted : 05/10/2014 6:30 pm
 cnud
Stuck a polar soft strap on mine. Been consistent ever since
Posted : 05/10/2014 6:49 pm
Just to be clear, this means using a Polar soft strap (which are about £18) with your existing Garmin transmitter. The Polar transmitter isn't compatible as it doesn't use ANT+
Posted : 05/10/2014 6:57 pm
http://www.cardiosport.com/products.html ... works flawlessly with my
800
Posted : 05/10/2014 7:13 pm
Stupid egg-sucky question... you have changed the battery, yes?
I found this miraculously improved the performance of mine 🙂
Posted : 05/10/2014 7:25 pm
timely question. I'm getting fed up with my garmin transmitter cutting out when I get close to max HRM. Was thinking of posting asking for suggestions of alternatives 🙂
Does anyone do transmitters that are Bluetooth/Ant+ or it that just asking too much of the battery
edit: clicks though on the Cardiosport link above and guess what, bluetooth and ant+. Question answered before asked - stw rocks
edit2: ah, you have to change something to switch. still pretty good though
Posted : 05/10/2014 7:30 pm
 2002
I have changed the battery twice and even fitted the battery the wrong way round which it said to do online to reset the unit before you re fit a new battery. I even use some ultrasound gel which sorted it for a while but it now keep dropping out and giving very low readings.
Posted : 05/10/2014 7:55 pm
That's exactly what happens with mine so i'm happy to know it's a real issue rather than something funny about the way i use it
Posted : 05/10/2014 8:09 pm
 SamB
I had the same thing - spikes and massive low dips with my Garmin HRM band. Switch to Polar and it's been consistent ever since.
There's a guide to the conversion here: http://fellrnr.com/wiki/Garmin_Heart_Rate_Monitoring
Posted : 05/10/2014 8:17 pm
Mine started playing up and I switched to the Garmin wearlink band, has been fine since.
Posted : 05/10/2014 9:31 pm
