Garmin 810 stuck in...
[Closed] Garmin 810 stuck in diagnostic mode
6 Users
As per title, but how the hell do I get back to normal screens. Even rebooting makes no difference. Many thanks if anyone knows
Posted : 06/09/2020 7:34 pm
Check that a button isn't jammed in.
Posted : 06/09/2020 9:15 pm
Mine did that, you have to do a full factory reset to get it out of the loop. Can't remember the buttons you hold down and in which order but it took 2-3 attempts for it to work.
Posted : 06/09/2020 9:55 pm
Had similar a couple of times a few years back. I vaguely remember simultaneously holding the power & right key (I think) for like 1 minute (longer than you think you should).
You've not got many options really. Hold some key combinations for a while and see if it restarts.
Oh, and make sure the memory card is taken out. I had this cause a hang once so its worth getting it out of the way!
Posted : 07/09/2020 10:09 am
The Garmin online chat support is pretty good, especially if you are in the UK.
Posted : 07/09/2020 1:37 pm
My watch did that, then it heated up and died 🙁
wasn't an 810 on a positive note.
Posted : 07/09/2020 2:04 pm
