Garmin 520 Plus use...
[Closed] Garmin 520 Plus users.....
3 Users
How are you loading courses on to your GPS?
I've previously used plotaroute.com to create a tcx file and dropped it on to the GPS when plugged into laptop. This is no longer working... It could be plotaroute causing the problem I suppose, so if so what sites are you using to create the route? Cheers
Posted : 15/03/2019 9:36 pm
Only got mine this week.im using strava routes from Garmin connect it seems to work well.
Posted : 15/03/2019 10:04 pm
Assuming its the same process for the 520 as my 510, I create a .gpx, then convert in www.gpsies.convert.do on my PC; then open Garmin Connect & import *.crs and bluetooth it to the Edge.
It's easier if you are following mapped tracks the whole way to create the course on a PC in Garmin Connect course builder as it snaps to the track.
The first way works but is such a faff thatI've largely given up navigating from the Garmin and I use an old phone on the bars with the Viewranger maps app running.
Posted : 16/03/2019 8:49 am
