garage chains &...
[Closed] garage chains & locks
7 Users
Has anyone got a link to the specialist motorbike & cycle lock company that sells high quality chains and locks?
They've been mentioned on here many times but I can't remember the company or product names.
thanks
Posted : 21/11/2013 2:27 pm
[url= http://singletrackmag.com/forum/topic/best-bike-lock#post-5526583 ]here you go...[/url]
Posted : 21/11/2013 2:31 pm
thanks
Posted : 21/11/2013 2:34 pm
[url= http://www.almax-security-chains.co.uk/ ]The Best (but expensive)[/url]
Posted : 21/11/2013 2:53 pm
Ive got the Torc ground anchor and the pragmasis 13mm chains and locks..Very very good.Wont stop someone chopping a frame to get the bikes though but will slow them down enough.
Pragmatism 13mm here too.
Posted : 21/11/2013 6:49 pm
If ur looking for a chain for a bicycle then the almax are too big as the links are the size of ur hand, literally!!
Pragmasis r better and u only need the 13mm chain if its for home use on a bicycle and u keep the chain off the floor, so it makes it much harder to bolt crop
Posted : 21/11/2013 7:38 pm
jimmon2008 - Member
Just for info, this makes no difference unless you've got it very high, needs to be at least a couple of feet off the ground- as long as you can get the handle of the croppers on the ground you can still use your body weight to cut, so realistically unless your bike is off the ground it's not likely to help.
The 13mm Pragmasis isn't rated as boltcutter proof incidentally but should put up a good fight against anyone with the wrong tools.
Posted : 21/11/2013 7:48 pm
