Garage is becoming a bit more cramped bike wise, looking at wall mounting as the only real solution. Any good reliable options out there ?
I use these from Halfords in mine. Wide enough for a 3" tyre. Put them high enough & there's room underneath for more kit. About £5.
[img] http://i1.adis.ws/i/washford/819748?$pd_zoom$ [/img]
just found these on Amazon???
http://www.amazon.co.uk/Mountable-Space-Saving-Cycle-Storage/dp/B005PMKM4W/ref=pd_bxgy_sg_text_y
Thanks for the ideas, those hook type do they mount the bike off the ground or does the back wheel have to touch the floor?
Off the ground, as high as you can lift your bike, if you want.
I've got 3 on the garage wall, at different heights so's I can get the bikes closer together, overlapping the bars.
i have mine on horizontal wall brackets as they take up the least space this way round.
The vertical ones are no good as the bars stick out into the useable space
me too - wall brackets that go under the top tube and hold 2 bikes horizontal.
Eats up much less space as long as you've got room for 2 bikes above another 2.
Downside is that you have to remove a bike to get to the one behind.
That's what I use too. I did try the hooks but they were a bit of a pain to get the bikes on and off.
Assuming you've got the front wheel out to save space and turning the bars, how tall do you rekon they'd need the roof height to be ?
reason I ask, I'm considering it for shed option but not sure how tall it would need to be
