Future proof wheels...
[Closed] Future proof wheelset ?? need something that will do q/r and 20mm ?
8 Users
I am after a nice set of wheel that I can keep for a while.
currently I run 9mmq/r forks however in the future I will more than likely upgrade to a nice set of either 15mm or 20mm bolt through??
what wheelsets are out there that can do both with different adpators??
cheers
steve
Posted : 01/07/2012 11:23 am
Hope, 'nuff said
Posted : 01/07/2012 11:28 am
superstar switch evo hubs can do that.
Hope proII front and rear is all you need for life.
Posted : 01/07/2012 11:29 am
+ 1 for Hope Pro 2 Evo build - So easy to change the front Qr - 15mm - 20mm with adaptors.
You can also change the rear to 10mm Bolt-thru or Bolt-up and stiffen the rear and it will fit in standard drop-outs.
I run them with Stans Flows and they are sweet 🙂
Posted : 01/07/2012 11:34 am
cheers.
who does the best hope builds then and what rims would you suggest??I want a nice strong wheelset but obviously not heavy.
cheers
steve
Posted : 01/07/2012 12:13 pm
You could try some of the hope hoops prebuilt wheels. I've used both good hand builts and hoops and the hoops are just as good IME.
I got handbuilts from Merlin but the hoops you just need to google for a cheap price.
Cheapest price I have seen is here http://www.progressive-bikes.co.uk/
He posts on here too.
Rim wise the flow would be good, reported to be strong* easy to run tubeless and lighter than anything else in the same marketing range.
*I've only ever ridden the XC rims like the crest but thye hold up as well as the equivalent Mavics.
Posted : 01/07/2012 12:18 pm
I got my Hoops from Cycleworld in Arbroath, Scotland.
They are a Hope Tech centre, so you can choose the hub colour 🙂
Chris is a nice chap and im sure he would price match and deliver
http://www.cycle-world.co.uk/
Posted : 01/07/2012 6:47 pm
Superstar switch evo's
Any axle front and rear , job done.
Posted : 01/07/2012 8:21 pm
If you want to spend a wee bit more, I just got DT Swiss 240s on Arch EX from actionbikes.de for £405.
Posted : 01/07/2012 8:35 pm
