Full Gear outers
[Closed] Full Gear outers
4 Users
I'm looking to run full outer cables on my new build, however i'm a tad confused. What do I do at the cable guides? Since the guides have the thin end to run the inner cable through, how do I use the full outer? Or do I have to cut it into 5 sections so its only the inner running through the guide bits?
Posted : 24/05/2011 10:28 pm
dremel/file.
or just zip-tie the outer to the frame.
Posted : 24/05/2011 10:30 pm
I'd just go with zip ties myself, but I think I've seen inserts like these:[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=28123 ]M Part Hose Guides[/url] used for full length outers...
Posted : 24/05/2011 10:35 pm
Cable ties it is then!
Posted : 24/05/2011 10:38 pm
Pick yourself up some 5mm tube from B&Q and use it to make anchor points for the cable...
Posted : 24/05/2011 10:52 pm
