Hi, i have narrowed my helmet search to 2 helmets but cant find the weight of the, hope you can help.
Fox Racing Rampage Size-Small
Giro Remedy Size-Small
Thanks
They both come in about 1100 grams if I remember rightly.
I have them both, and to be honest the fit is fairly similar on each. Don't think you can go wrong with either.
Before you do decide have a look at the Oneal Airtech, loads better helmat with new technology as oppose to a 10 year old mould
[img] http://t3.gstatic.com/images?q=tbn:ANd9GcSihVDVxho0_Gr-uOHV5XyW-hqwU22n2J2EvyGv5aZQXVYBmHcG_k6MetY8 [/img]
£110 and comes with the best locking device ever, no messing with d loops! Weighs in at under 1100g too
The two you mention are the same mould as the one Oneal sell for a RRP of £59.99
Wouldnt worry about weight, IMO it's not an issue as the weighs arround your head rather than on it, and venting isnt the end of the world, I've a mid priced 661 so neither the lightest or most vented but it coped with XC rides in Spain. Just cut out the fabric liner arround the vents to encourage more airflow made ahuge difference.
If you are worried about weight. My mate has a Kali and it is VERY light.
As above a 500g piss pot is lot less comfortable than a 1kg FF.
If your riding requires a FF the weight (within reason) is not that important.
Considered one of these?
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=58788 ]http://www.chainreactioncycles.com/Models.aspx?ModelID=58788[/url]
Very light and unobtrusive to wear. They have less lairy ones for £99 too.
i use kali avatar is stooopid light (lighter than a troy le carbon) and £200 🙂
