Hi,
My mate has a set of fulcrum raciing wheels, he cant get the freehub off and has asked me....cant see how to do this from his dogdgy phone connection. can anyone help?
Have a look on Youtube or Google it. I changed the the freehub easily enough on my Racing 55 wheel. I think I had to remove the nut on the FH side of the axle and then slide something off and get an Allen key in there. Cut and past this into your browser.
Depends on the wheel.
If it's a racing sport then you need to remove the axle and the NDS cartridge bearing and then the freehub unscrews with a 12mm allen key.
On my racing 3's you remove the nut on the drive side and it comes off clockwise.Put an Allen key in the other end to hold it.When it's off you can slide the short metal sleeve off then the freehub will pull away.
Nice one guys. I'll pass this on.
