Front mech with no ...
[Closed] Front mech with no cable stop? Possible?
10 Users
Got a single ring commute/urban bike with no cable stop for a front mech and would like a 2 ring option. Possible? How?
Posted : 04/10/2019 7:40 pm
Full length cable to a side-swing mech. Run the cable down the downtube and use the bottle mount points to secure it.
https://www.chainreactioncycles.com/ragley-universal-cable-guide-kit/rp-prod104665
Posted : 04/10/2019 7:57 pm
SJS cycles sell a range of bolt on cable stops, Origin-8 I think.
Posted : 04/10/2019 8:06 pm
Or clamp on guides, they used to make them for V-brakes etc. Chain device mounts like DMR used could also be modded to do the job.
Posted : 04/10/2019 8:08 pm
Or you can get top pull mechs that have the stop built in. Not sure of all the part codes but the FD M785 is a low mount 2x10 with a stop built in.
Posted : 04/10/2019 8:11 pm
 PJay
I bought a clamp on cable stop from SJS for my Swift; it's been flawless.
You can also buy clamp on Direct Mount adapters (the cable stop is then built into the front mech.
Posted : 04/10/2019 8:14 pm
E type bottom bracket mounting front mech with cable stop?
Does the back wheel have the clearance to miss a chain ring bigger than 32t?
Posted : 04/10/2019 8:52 pm
Easily - 44t in middle position at the moment
Posted : 04/10/2019 8:56 pm
First answer is the best answer.
Posted : 04/10/2019 9:32 pm
I got a bolt on clamp so i could run a double up front on a frame designed for x1. It means i can now fit a mech. it was a 'problem solvers' one.
Posted : 05/10/2019 1:28 pm
Or you can get top pull mechs that have the stop built in. Not sure of all the part codes but the FD M785 is a low mount 2×10 with a stop built in.
This is much better than messing around trying to fit cable stops. You just run a continuous cable outer from the shifter to the mech. Dead easy.
Posted : 05/10/2019 1:44 pm
