front mech shift is...
[Closed] front mech shift issue
4 Users
I have an issue with the shift on my front mechanism that is becoming increasingly frustrating. I ride a gt zaskar carbon 100 expert, with x9 drivetrain. Front mech is bottom pull. I can start a ride with a great shift on the front but find as it gets muddier it won't shift up. But if I add tension at the shifter I cam get it to change. As you can imagine this is annoying. Any tips or ideas? Aside from 1x10.
Posted : 06/01/2013 4:57 pm
Start with changing cables and outers.
Along with that strip and clean the mech and then set up the upper and lower limiters from scratch.
Adding tension wont do a thing with issues like this.
When dealing with mechs the clever bit is the shifter and not the mech.
Hope this helps.
Posted : 06/01/2013 5:01 pm
Cheers Monty. Will get a cable kit and replace.
Posted : 06/01/2013 6:13 pm
Make sure there is no rubbish stuck in the mech, twigs ect as that could stop it moving properly
Posted : 06/01/2013 6:41 pm
Also make sure the cable is clamped properly, and not gradually creeping it's way to slackness.
Posted : 06/01/2013 7:19 pm
Problem is it gets bunged up on the ride. Will check cable grip as that seemed a bit loose when I tightened it earlier. But didn't fix problem when out.
Posted : 06/01/2013 7:46 pm
Sounds like old clogged cables and outers to me.
Ebay is your friend.
Posted : 06/01/2013 8:07 pm
If it's getting bunged up, make a mud-flap using an old inner tube zip tied to the frame, been using mine for years now, mechs last a lot longer too.
Posted : 06/01/2013 8:08 pm
