Front mech for 36T ...
[Closed] Front mech for 36T double
6 Users
 sok
I'm after a front mech for a 2x10 double which I'll be running with a 36T big ring (I know, I know - but weedy legs and big wheels).
The blurb from Shimano states the mech does 38-44T. Has anyone tried one on a 36T with any success or is it better to go for a triple mech?
Thanks y'all
Posted : 13/03/2013 11:58 am
36 or 38 is what most "trail" setups would use. It's very common.
Yes. Go for it.
Posted : 13/03/2013 12:07 pm
The SLX M665/7 double was specifically designed for a 36T, but its 9 speed. Imagine any of the 10sp double FDs will cope, just won't quite match the curve of the chainring thats all...
Posted : 13/03/2013 12:49 pm
36/22 using a standard SLX double mech here (9 speed)...
From memory so long as you have no more than 14T difference between the two rings (i.e. 22/36, 24/38, 26/40, etc) then it'll be fine, I think that still holds true for the 10 speed kit, someone will be along to tell me I'm wrong soon though...
Posted : 13/03/2013 1:39 pm
Iv run Shimano double and bash for years now on both my hard tail and full suss. 36x22 on the front 34X11 on the back - standard XT equipment but with a medium cage rear mech.
I found it great on my light weight hardtail and sticking with it. However on my heavy 160mm all mountain rig I wasnt totaly happy.
Reasons are.....
The ratios I mentioned above are 2T above recommendations for the medium cage rear mech - It works fine on the hard tail but with the extra chain growth of a full suss its never been ideal and you have to be careful with gear combinations.
I found the 36T ring a bit big for the heavy bike anyway and found myself in the granny ring more than I would like - once again the ratio is perfect for the sprightly hardtail.
36 to 22 is a big jump for the chain to make when shifting and I do occasionally loose the chain. As long as you remember to peddle carefully while doing it its ok though.
So - Im keeping the hardtail setup but Iv switched the Full suss bike to 34x22 and 34x11 - Iv also gone 10 speed with XT clutch mech.
Initial thoughts - perfection
Posted : 13/03/2013 3:33 pm
 sok
Sounds like I should just get on with it then. Thanks
Posted : 13/03/2013 5:07 pm
Unless there is a new 10 speed one the old 9 speed 22-36T SLX FD would be the best bet. It should work fine with a 10 speed shifter.
Posted : 13/03/2013 5:09 pm
