I'm looking to get a conversion kit for my front hub, so I can adapt from 15mm through axle to quick release.
I'm unsure what brand my front hub is*, so I need a bit of guidance to be sure I'm buying the correct item.
[i]*The rims are Alex Rims DP20, and the assumption is that the hubs might be the standard NovaTech hubs.[/i]
Would something like this Nukeproof conversion kit be suitable?
http://www.chainreactioncycles.com/nukeproof-conversion-kit-15mm-to-qr/rp-prod80192
Cheers.
There is no reason that the nukeproof conversion won't work as you are converting from one standard to another, and that facilitates just that.
Unless, of course, your bearing spacings happen to be different to those that the adaptors were intended for, in which case you could end up with hubs wider or narrower than your fork dropouts.
All the 15mm hubs I have seen just have the bearings with no futher spacers, so they just slot in the fork, and the maxle then goes through, hence my conclusion that to change from 15mm through to QR will all require the same adaptors.
Thank you guys. 🙂
Appreciate the help.
I think Superstar hubs are novatech, try [url= http://superstar.tibolts.co.uk/product_info.php?cPath=51&products_id=288 ]these![/url]
Some hubs need a new axle to convert them properly, not just spacers.
Email/ring the guys at Justridingalong - they have a great deal of knowledge (and kits in stock if needed).
Lucky you. Just cost me over £50 to swap a 20mm to 15 mm axle in a Chris King hub. It's a sodding aluminium tube fer Pete's sake. What price vanity, eh?
