Front derallieur ca...
[Closed] Front derallieur cable loose when in granny ring
2 Users
Is this normal? Or is it because I'm using an xt 10 speed chainset with 9 speed xtr derallieur and shifter? Have I gone completely mad? In sure it's normally vaguely tight. At least there isn't any slack.
If I tighten the cable when it's in the granny ring then when I'm in the middle ring at the front and the largest sprocket I get bad rubbing.
The derallieur is aligned perfectly.
Does anyone have any suggestions or can confirm this is normal as in getting fed up trying to work out why 🙂
Cheers,
Posted : 06/08/2014 4:21 pm
Does it shift correctly?
Posted : 06/08/2014 4:40 pm
It does. It's just the cable being loose that's annoying me. That and wondering if that's normal that it's loose.
Posted : 06/08/2014 4:42 pm
It can be like that, yes.
If it works, no worries. You can try undoing a barrel adjuster to tension the cable a tad, but its likely you'll lose crisp downshifts, so I'd leave it.
Posted : 06/08/2014 5:33 pm
Ok cool. Thanks for the conformation. Much appreciated!
Posted : 06/08/2014 6:01 pm
