From 32-T to 30-T -...
[Closed] From 32-T to 30-T - how many links out?
10 Users
Presume removing just one link will keep the chain as tight?
Posted : 28/04/2015 2:52 pm
2 I would have thought, given that each tooth has a link passing over it. So lose 2 teeth, lose 2 links?
Posted : 28/04/2015 3:00 pm
As was embarrassingly pointed out to me a few days back, you're only losing 1 tooth (since the chain wraps around only half the chainring) and since chains are 2 links minimum change, most of the time you won't change the chain length (unless it was a bit loose before).
Posted : 28/04/2015 3:04 pm
None most likely, possibly 2 (1 full pair). Depends whether you had a slackish or tightish chain before. If it was a bit slack remove a pair, if it was a bit tight leave as is. losing 2 teeth is only 1 tooth in use, so its not a full pair of links, so there is no 'right' answer to the question.
Posted : 28/04/2015 3:05 pm
I never removed any going from 34-32. It's fine.
Posted : 28/04/2015 3:10 pm
Didn't need to add any going from a 30T to a 32T Oval.
Posted : 28/04/2015 3:19 pm
Either 0 or 2. I use the big/big/+2 method
Posted : 28/04/2015 4:43 pm
I went from 32 to 30 and have not changed the chain length. Shifting is still sweet. In fact, if anything, it's better. (XO1 Groupset.)
Posted : 28/04/2015 8:41 pm
Depends how tight your chain is now.
None 34-32 for me and works fine.
Posted : 29/04/2015 12:00 am
another zero vote
run 2 wheelsets on my drop bar hybrid aka cx advenure racer XT long cage
1 has a 11-32 the other a 12-34 no problems with chain when swopping
Posted : 29/04/2015 2:22 am
