French cleats
[Closed] French cleats
7 Users
Hi,
I'm wanting to knock together some French cleats for my garage.
Does anyone know of any national diy/joinery type store that would sell me the wood and do the angled cuts required?
Cheers,
Posted : 27/01/2015 8:18 pm
No ideas then?
Posted : 28/01/2015 7:10 pm
Any number of places will sell you the wood...
Some timber supply places will machine wood for you, but there's usually a set-up charge, and / or a 'per m' charge.
Huws-Gray did ~60 metres of architrave for me to match an existing pattern a few years ago (Llandudno Jn, but they have branches throughout the NW). IIRC, the set-up charge was £60, then they would run as much as you wanted for the cost of the wood. There will be similar elsewhere.
I can't believe it would be cheaper than buying a circular saw or a plane (or even a handsaw) and knocking the corner off some PAR yourself unless you have an enormous garage.
What are you going to hang off them?
Posted : 28/01/2015 9:36 pm
Stand on pedals, shrug shoulders to clip-in?
Posted : 29/01/2015 7:30 am
Does it need to be a national chain? That'd be more of a job for a local timber yard or DIY store.
Posted : 29/01/2015 8:19 am
 mj27
could you do it with some chamfer edge skirting in 25mm thickness. Go to a timber merchants and explain what you want to do, they should try to help, it's a sale to them if they get it right.
Posted : 29/01/2015 8:27 am
Another option is aluminium split batten extrusion.
Posted : 29/01/2015 8:28 am
 FOG
I thought this was a euphemism!
Posted : 29/01/2015 10:07 am
Any local joiner with a table saw big enough for full sheets could rip it easily. Take a few minutes - £30?
If you can't get the sheets to them, then you could get them cut down to double width at the timber merchant, then do the angled cut at the joiners.
I was going to use 18mm birch ply, but it doesn't necessarily have to be as posh as that.
Posted : 29/01/2015 10:24 am
