Freehub Allen Key s...
[Closed] Freehub Allen Key size?
3 Users
Anyone know what Allen Key/Hex size to open up a Shimano freehub? Trying to find an Allen Key bigger than 8mm in the shops is impossible so just want to make sure I order the right size.
BTW, I'm assuming they're serviceable? When I last had the cassette off I noticed mine felt a bit gritty and wobbly.
Cheers 🙂
Posted : 29/04/2015 7:19 am
[i]BTW, I'm assuming they're serviceable?[/i]
*hollow laughter*
you can try flushing it through with degreaser, rinse and dry but it tends to be a short term solution, ime.
Do check prices on new hubs from crc etc before you buy just a freehub, prices are sometimes not much different and you get a new axle and set of bearings with a new hub...
Posted : 29/04/2015 7:23 am
Good to know, thanks.
What about the Allen Key size?
Posted : 29/04/2015 7:36 am
10mm usually.
I just got a 10mm hex 1/2" drive socket from my local Halfords and used that.
Posted : 29/04/2015 7:38 am
Good idea. I did think of that but worried it might not be long enough. Thanks.
Posted : 29/04/2015 7:42 am
measure how far you need to go in using your 8mm key and you'll be sure the 10mm is long enough then.
Posted : 29/04/2015 7:56 am
 cp
most sets, even cheap ones, have 10mm keys in.
[url= http://www.toolstation.com/shop/Automotive/d60/Hex+Keys/sd3194/Ball+End+Hex+Key+Set/p15648 ]This one [/url] for a tenner even gives you a set of Torx - they're good quality keys.
Posted : 29/04/2015 8:00 am
