Frankenfork!! 150m...
[Closed] Frankenfork!! 150mm Revs to DPC conversion advice required
3 Users
seems like its a nice upgrade if weight is not first consideration. keen to try it out!
looks pretty straight forward apart from the missing topout bumper, anyone else had a go at this on a 150mm rev with a sektor dual position coil assembly?
what parts did you fit and how did it work out?
tricky bit seems to be the topout spring?
Posted : 08/05/2014 10:24 pm
I think LoCo have done a few.
Posted : 08/05/2014 10:38 pm
I dunno about the conversion but if you do decide to go for it and need a DPC spring I've got a 150mm standard (red) DPC spring from a set of Sektors with the top cap etc... Only a few rides old whilst I waited for the stiffer one to arrive.
Email is in profile if your interested
Carl
Posted : 09/05/2014 6:13 am
thanks carlos, but I would need a firm one as well.
Posted : 09/05/2014 5:02 pm
just an update for anyone who may be considering.
used a 150mm u-turn coil, dropped it in, works a treat,
cheers all!
Posted : 30/05/2014 10:55 am
