Frame size help nee...
[Closed] Frame size help needed please.
10 Users
Hi, i am looking to get back on to a bike after a 20+ year gap.
I will cycling mainly for pleasure in parks, canal paths (anything flat as the missus will be with me).
I need some advice on whether to go large frame, short seat post or smaller frame and longer seat post.
I am 6'4" so I have been looking at a 22" or larger frame, but out on my travels I see some prettty tall guys on smaller frames and long posts and wondered what the adavantages/disadvantages of either are.
Any advice greatfully received.
Posted : 26/02/2012 12:44 pm
I'm the same height and have long legs. I think you need to be looking at 20"+ frames if you want the saddle to go up to a height you can pedal properly on. I ride a 21" Orange and would not want it any smaller.
Posted : 26/02/2012 12:56 pm
Cheers for the reply, will probably go for a 22", but just wondered if there were any advantages to the smaller frame and longer seat post.
Inside leg of 34" by the way.
Posted : 26/02/2012 7:50 pm
Hi There, I'm the same height as you and have a similar inside leg, the small frame thing is fashionable and will give some extra clearance if things get 'interesting' but for the sort of riding you describe I'd just get a larger frame and avoid putting a load of unnecessary leverage through the frame as you would with a small frame/long seatpost combo. Does mean you won't be able to describe it as 'flickable' though 🙂
Posted : 27/02/2012 9:10 am
I think also the smaller the frame you get the lower your bars will be or the more steerer spacers/higher rise stem you'll need to bring them up.
Posted : 27/02/2012 10:42 pm
Suggest going to a bike shop and seeing if you can take a test ride. You could also ask them if they can fit/swap a stem to fine-tune the reach.
Posted : 28/02/2012 4:25 pm
Same problem, 6ft 4in, however my legs are "relatively" short at 34in compared to mates around my size.
I generally go on top tube length. I.e need to ride a 24.5in to 25in.
Problem you have, depending on your weight / power, is the extended seatpost puts a strain on a smaller frame, particularly carbon, even though you may be within the requirement of the seatpost / frame / seatpost insertion.
Posted : 28/02/2012 4:37 pm
A fair bit shorter than you but still tall (6.2"), my personal preference is for, smaller than bigger bike wise but with in reason. I find a smaller bike is a bit nipper (although of course this is a generalisation, due to different geometry e.c.t) but find the bigger bike can get too long and find you end up with a bit of a feeling of, front wheel...then the rear come along a while later, a bit disconnected.
But I used to prefer a longer bike as it was more stable but tended to like smaller bikes as my skill level has gone up.
But saying that I am talking about riding a 19" instead of a 20/21" not 17/18". Think it does come down to personal preference but also staying with sensible parameters so you can still have a good reach to the bars and a reasonable amount of seatpost still in the frame.
Posted : 28/02/2012 4:53 pm
I am considerably shorter than you but find myself in a similar dilemma. If I go large I benefit from the long top tube which makes the bike feel more like a road bike. I find a stretched position more efficient for mile crunching. It is also extremely stable on single track or long swooping downhills. I currently ride a frame one size too big for me (according to the manufacturer) and fit a short stem and riser bars when I want to ride technical stuff. It works for me.
Posted : 28/02/2012 8:05 pm
I'm 6'4" with 36" legs and ride a 22" Cube AMS 130, I was going for the 20" and a bit more seatpost but they have a shortish top tube so went for the 22".
You need to check out the geometry of particular bikes you like and try them out, I liked the 54cm Zesty but had heel rub on the flared rear end.
I'm thinking of a 29er next time which are supposed to be a good fit for tall fellas.
Posted : 29/02/2012 9:38 am
Im 6' 3" and have a 22" orange, had 20" for the last 5yrs+ and always thought they were a good fit but the 22" really makes a difference and I can finally say ive found something that feels right
Posted : 29/02/2012 9:57 pm
