Been off the bike for a while as I've been doing up the new house.
1st ride out last night and my suspension felt a bit off. Probably needs a reset as it wan't quite right anyway.
As a base, what are you guys running on you X2's & Yari?
I'm 14.5 stone kitted up. Shock is a 240 x 76mm, forks are 180mm.
Might try and hire a Shockwiz from the LBS if necessary but thought I'd see what you lot are running to get me somewhere near.
Ta 🙂
Not sure anyone can recommend base settings without at least knowing what the bike is, especially with an X2 (or DHX2, CCBD etc).
FWIW, on an HB160, I have a base setting of 10 each for HSC/LSC, 11 each for HSR/LSR (from closed). Then fettle after a couple of rides (currently 8-9 on compression, 13-14 on rebound).
For the Yari, compression wide open, rebound, no idea - just twiddle until not too fast, not too slow.
You can get a base line for pressure and rebound for the Yari on the Rockshox app : just type your serial number and weight. For your weight it will probably recommend just under 100psi and 8 clicks from the slowest.
