Fox volume spacers ...
[Closed] Fox volume spacers for nude/Scott shock
5 Users
I bought some genuine volume spacers for my rear shock on a 2017 Scott 710. When I tried to install one it is just loose in the chamber and doesn't clip tight on the shaft as I  would expect. It also seems to reduce the stroke as the spacer won't allow the shock to fully bottom out. Have I got the wrong spacers. I could only see one type for the fox float shock. The nude version looks identical. Any one else had this same problem.
Posted : 08/09/2018 1:34 pm
There should be a four letter code on your shock somewhere.. you can stick that code into the fox website and thatll tell you which spacers that particular shock takes.
Posted : 08/09/2018 4:30 pm
You cant use volume spacers in the nude shock due to the tc internals already taking up space in the can
Posted : 08/09/2018 7:39 pm
There's a thread on mtbr about using a .3 spacer. Links to a 2014 part number though so could be trial and error install.
Posted : 08/09/2018 8:06 pm
Thanks for the help. I will do a bit of research into this and see what I can get my hands on.
Posted : 12/09/2018 1:52 pm
I had the same problem. Turns out the nude shocks don’t take volume spacers that clip on the shaft - they fit inside the wall of the can (I don’t know how many times I went looking for the one installed in mine before I found it)
I got both of the below items and can confirm they fit the newer Nude shock (2018 in my case). There was a 0.1” spacer in mine as standard.
Hope this helps
https://activesport.co/epages/80c85f8f-7a95-4b1c-9c30-e64b314f3f2e.mobile/en_GB/?ObjectPath=/Shops/80c85f8f-7a95-4b1c-9c30-e64b314f3f2e/Products/233-00-214
Posted : 22/01/2019 4:10 am
