Fox Shock Problems
[Closed] Fox Shock Problems
3 Users
The Propedal lever on my Fox RP23 Boost Valve Shock has stopped working; i.e. its gone loose and doesn't spring over to switch the damping on and off. Other than this the shock seems to be performing fine.
Anyone else had this issue with a Fox Shock? Or got any advice on sorting it?
Paceman
Posted : 19/04/2014 7:01 am
There are various little Allen keys on the shock. One seems to grasp the shaft you could tighten that a bit.
Posted : 19/04/2014 7:08 am
Cheers Zippy, I've tried that with no luck 😕
Posted : 19/04/2014 7:16 am
Anyone else had this issue?
Posted : 21/04/2014 7:31 am
Pretty sure it'll need a full strip to sort that one, Loco would probably confirm, but think he's away for the weekend.
Posted : 21/04/2014 10:37 am
Cheers Coatesy, I was half expecting as much.
Posted : 21/04/2014 4:05 pm
