Fox shock issue - w...
[Closed] Fox shock issue - warranty or quick fix?
3 Users
Got a rebound issue with my Fox Float evol shock. The rebound knob just spins when you turn it counter-clockwise (faster rebound), and there are only six or seven 'clicks' going back the other way (manual says there should be 11). If you leave it in this free-spinning position, there is a noticeable clunk about a third of the way through the travel. Moving it a couple of clicks makes it compress smoothly again.
Clearly something's come adrift somewhere - is this something anyone else has encountered/fixed?
It's still within warranty.
Posted : 19/01/2020 10:42 am
Bump for the evening crowd.
Posted : 19/01/2020 4:21 pm
If under warranty, send it away. Not sure what your dilemma is here, if you go poking about inside they might not honour the warranty.
Posted : 19/01/2020 4:25 pm
****ed, send it back
Posted : 19/01/2020 4:34 pm
I am pretty resigned to warranty, just checking in case there was something simple I'd overlooked which would save me losing the bike for a few weeks, that's all.
I'm not going to dig around in it, that's for sure!
Posted : 19/01/2020 4:47 pm
buy a cheap shock to keep you on the bike if you dont want to be without
Posted : 19/01/2020 6:02 pm
As a follow up to this, good service from Silverfish to report - sent it on Saturday afternoon, turned up 10 minutes ago with an 'anti-clunk' assembly fitted, whatever that is!
Thanks to Storm Ciara, didn't even miss a ride!
Posted : 12/02/2020 8:26 am
It means they've attached the rebound assembly back onto the shaft properly 😉
Posted : 12/02/2020 10:49 am
