Fox RP23 boost valv...
[Closed] Fox RP23 boost valve high volume air can problem, help!
4 Users
I decided to put one of the fox air volume spacers in 2011 RP23 BV high volume unit but am now stuck as when I try to screw the air can there seems to be a sleeve that moves round and up and down a couple of mm but not unscrew and there is only about 50mm below this which is impossible to grip on to to unscrew.
I now don't know whether the sleeve is tightened up as it still goes round, I would like to avoid the eye rolling at the LBS if anyone can help.
Posted : 01/02/2012 12:04 pm
I have the very same thing, although I haven't got around to taking a proper look at it yet.
Posted : 01/02/2012 12:07 pm
Are you talking abour the outer air sleeve?
If so remove the retaining C clip at the bottom and slide the outer sleeve off the main unit (you'll have to give it a bit of a yank as there is a lip and it has two o rings). This then will allow you to unscrew the main body
Posted : 01/02/2012 12:09 pm
Thanks for the reply steve, there looks there is a seal with a slight gap is that the C clip. If so how would you get it out as I don't want to damage it.
Posted : 01/02/2012 12:18 pm
you got any pics, does it look like this
Posted : 01/02/2012 12:22 pm
I use one of these on the lower (narrower) part of the air can:-
[url= http://www.boa-uk.com/constrictor/babyboasoft.html ]Get a Grip ![/url]
No need to disassemble the sleeve 🙂
Posted : 01/02/2012 12:25 pm
Yes thats the bugger, can't find any guides or videos for it online.
Posted : 01/02/2012 12:27 pm
All sorted now, like you said just needed to ease out the clip and gently slide the sleeve down. Used the medium spacer and its meant I can drop nearly 30psi for same sag.
Just have to see if it makes any differance on the trail now.
Posted : 01/02/2012 12:52 pm
