Fox piggyback shock...
Fox piggyback shocks - anyone not needed parts replacing?
12 Users
4 Reactions
My Fox piggyback shock needed expensive replacement parts, more than doubling the cost of the service.
Everyone I know has faced similar.
Anyone managed to only have a basic service on one?
Posted : 29/04/2024 12:07 pm
My DPX2 still going strong, just had a couple of basic services in 4+ years
Posted : 29/04/2024 12:08 pm
I had one, I think a DPX2 on a Pivot. It got nothing except a service every few years and hsd about 9 years use when I retired the frame.
Posted : 29/04/2024 12:19 pm
The older DPX2 and the newer Float X (which is superb, the best shock they do) are fine. The Float X2 is a pup and well known for being so.
(The Float X took what was good about the lighter/smaller DPX and added the good things from the Float X2, such as replacing the hard plastic bottom out bumper with the nice big squishy elastomer one).
Posted : 29/04/2024 12:22 pm
What parts did it need? And which shock was it? Was it like for like replacements, or upgrading a Float X2 to current spec?
Posted : 29/04/2024 12:23 pm
Which company T.. Something ?  They are well known in my clubs circle for upselling on slighly worn parts.
Posted : 29/04/2024 1:42 pm
It's a float X, just over a year old.
Needs body, sleeve and eyelet. Not warranty as dirt ingress
Treated better than shocks I have had in the past that never needed any expensive replacement parts.
Probably shouldn't have bothered getting it serviced, just done an air can service
Posted : 29/04/2024 2:00 pm
I’ve got a float X, really get on with it. I did do an air can service as soon as I got it though. Had it serviced once so far.
Posted : 29/04/2024 2:15 pm
so basically all the exterior parts except the piggyback?
Posted : 29/04/2024 3:25 pm
kelvin and kelvin reacted
That sounds odd - most of a shock being replaced there. If it were a Float X2 I’d have understood as there are fundamental problems with that. Mine went for a service (Silverfish) and they replaced a lot of bits with 2024 spec stuff (new trunnion bit / different seals / new Kashima bit at ) - although they did that within the standard service cost. It was  secondhand shock out of warranty so I thought that was ok.
Surprised if the float x needed that.
Posted : 29/04/2024 4:54 pm
My 2020 X2 was terrible, every time it went to TF Tuned to be serviced it was costing £250
The last time i decided to send it to FOX instead, again it needed lots doing but they upgraded the internals to the 2024 internals and its been absolutley fine since then
Posted : 29/04/2024 10:04 pm
TF were never the same after Tim sold.
Posted : 30/04/2024 7:54 am
Do they still return the original parts to you? Hopefully you can see the reasons for the change when you've got them
Posted : 30/04/2024 9:50 am
