Normal service procedure. Fitted lowers. 30ml 10ml oil in legs. Bolted back up. Forks feel really stiff and sluggish to return.
Oil in wrong place? I'm a muppet?
Chris
Ps 2012 Talas 29 32
Usual process is strip and rebuild at this stage
Thanks Mike, that was my thought too!
TALAS? Did you set the pressure with the fork upside down? From bitter personal experience that will force oil into the air side of the TALAS system, resulting in snot and tears.
Apart from that though I can't think of any reason why it wouldn't work, unless you overtightened the damper side nut and snapped the rod.
Yup, I pumped it up upside down....snot and tears it is!
