My 2007 Stumpy HT came with Fox 90rl forks.
Is it possible to take out any internal spacers in them to make them 100mm rather than 90mm?
I did discuss things prior to buying some 100mm forks a few years ago & the LBS said something about taking spacers out of the Fox forks but it's been such a long time I might have misheard them.
I still have the Fox forks & I would prefer to run them @ 100mm if possible.
Any help &/or advice gratefully received.
You probably only get 80mm due to the nature of them being fox so i wouldnt get too hung up by numbers
From memory the 90mm forks were never sold after-market so there is a good chance that they are just the 100mm fork with a 10mm spacer on the air spring- only way to know for sure is to open them up. It's not a massive job and you should find everything you need to know here...
http://service.foxracingshox.com/consumers/index.htm
A
Cheers ansdy thats what the LBS guys said but it was such a long time ago I thought I'd ask on here first.
