Fox fork loosing ai...
[Closed] Fox fork loosing air pressure
4 Users
 dyls
Anyone technical minded know why my fox fork 34 has suddenly started loosing air pressure over a few days? Is it best to send it in for servicing or is it an easy fix?
Posted : 03/05/2019 9:04 pm
Probably needs a new o-ring somewhere in the air spring. Easy is subjective 🙂
Posted : 03/05/2019 9:06 pm
I had this ongoing problem with my fox 36s.
Using warm soapy water I tracked the leak down
It turned out to the be the air valve on the top of forks. It has a ?10mm lock ring around it and try tightening that. Otherwise you need to get a new oil ring or sea for it. If they are new it should be a warranty issue.
Posted : 03/05/2019 11:32 pm
 dyls
Haven’t had a chance today but will look at the air valve over the weekend to see if thats the issue then. Can you buy these over the counter?
Posted : 04/05/2019 4:30 pm
Check that the valve core is tight.
Posted : 05/05/2019 9:33 am
