fox float travel ad...
[Closed] fox float travel adjustment help
2 Users
right i got a set of 2009 140mm travel floats
my question to you all is if i reduce the travel will this reduce overall height of the fork.
the reason i ask is i have a frame and 140mm travel is just to much so was thinking to un-slacken 😕 the geometry a bit i could shorten the forks.
your thoughts?
Posted : 31/05/2011 8:50 am
right after not receiving an instant response I got bored and tried it it effects the lot!
Posted : 31/05/2011 11:36 am
Learn by doing....so time well spent (all time fiddling with bikes is well spent) 😀
Posted : 31/05/2011 11:38 am
