Fox Float RL shock ...
[Closed] Fox Float RL shock advise?
4 Users
 daj
Well looked like me enduro shock finally gave up after FOD last monday, lost all air when standing in the garage after pumping it back up that night. Ordered a rebuild kit and did that today, Pumped it up to 200psi and checked it 4 times since about 5pm and its now at 160psi ??
Guess I am going to be looking for a new shock? unless they lose 10 psi when you check the pressure everytime?
What are my options for the Enduro 03/04 ??
Posted : 03/02/2009 9:34 pm
Hi Daj, hijaking this a bit now but did you see my comments following your post on the sizing of the Humvees... interested ?
Posted : 03/02/2009 10:56 pm
daj,iirc,every time you screw on the shock pump,it does take some pressure out of the shock to fill the hose & gauge on the pump-hence the low reading.
So pump shock up to your preferred pressure,& all should be well.
If it was me,i'd pump it up to pressure now,leave it for 24 hrs before checking it again,& if there is just a 10psi drop,then its as my 1st paragraph.
hth.
Gaz
Posted : 03/02/2009 11:03 pm
 daj
Hello mate,
I didnt see it, but have now. No probs just off to bed will mail you in the morning.
daj
Posted : 03/02/2009 11:04 pm
They will lose pressure when you attach a shock pump, it's what operates the gauge. If you want to check for leaks then hold it underwater and look for bubbles.
Posted : 03/02/2009 11:06 pm
