Hi
I have a set of Fox Fit CTD forks.
I am considering buying the remote kit for them.
Does anyone use them? How good are they at switching between the CTD?
Thanks in advance.
really good if your finger is in the right place. I'd rather have the shock one though. They work together if you want to lock both together.
Ok thanks.
I am running a hardtail so don't need the shock one but I can understand having that one.
Mojo said 4 to 6 weeks delivery of remote!
Are there any bargains out there?
try google...
It's a fox only part and it's a change to the top cap I think, generally fitted with a service.
Thank you.
I have a pair of unused F100 ctd forks with the remote cartridge if you're interested in swapping cartridges.
Hi
My forks are fox float 29er.
120mm reduced to 100mm.
I thought it was just a case in replacing top cap?
My knowledge in forks is not the best.
Thanks
