Fox F120 - Is it po...
[Closed] Fox F120 - Is it possible to shorten them to 100mm?
6 Users
Pretty much as title.
I have some fox f120s that now on the bike appear a little long and may throw the geometry out. Is it possible to modify them to say 100mm? Preferably cheaply and easily?
Otherwise I might hve to sell them and get some f80s which may be too short!
Posted : 14/06/2010 5:03 pm
Yes it can definitely be done. I think you just shift the internal spacers around
Posted : 14/06/2010 5:20 pm
Yup you can do it you will need to fit a 20mm spacer to the negative spring
Posted : 14/06/2010 5:38 pm
I don't have 'f' series forks, but on floats, it's just a question of opening up the LH leg and fitting a 20mm spacer. I assume they're fairly easy to get hold of - I just fitted an old one that came out of an ancient vanilla. (Might have another if you need it, but can't check until friday).
EDIT - pretty much what everyone else just said...
[url= http://www.mojostore.co.uk/acatalog/Forx_Travel_Spacers.html ]http://www.mojostore.co.uk/acatalog/Forx_Travel_Spacers.html[/url]
Posted : 14/06/2010 5:43 pm
Can this be done with the F series? I thought it was just the Floats? Killer can you post up if you do it? Thanks.
Posted : 14/06/2010 5:46 pm
