fox dhx5 coil rebou...
[Closed] fox dhx5 coil rebound dial position.
2 Users
Hi gang.
Is it safe to spin the shaft round 180 degree so the dial is on the opposite side to the air chamber.
It,s going on my spicy and is easier to access if it,s underneath the linkage.
cheers..
Posted : 24/07/2011 8:45 pm
if it'll spin without much force, fill your boots, check your rebound again once it's rebuilt.
Posted : 24/07/2011 9:18 pm
yer just turns.no spring on obviously.
Just thinking along the lines of a fox float which you can spin to no effect as it's just a seal head on tuther end..
Posted : 24/07/2011 9:48 pm
