Fox 36 lowers rando...
Fox 36 lowers random spring washer
3 Users
Hi all,
Just gave my 2022 forks a lower leg service. As I was sliding them back through the headtube I noticed a spring washer on the floor that could only have come from when I disassembled them. I think it's from the rebound dials but not 100% sure. Can't find anything about it in the service manuals/fox website.
The mystery washer:
[url= https://i.postimg.cc/X7b9cF3v/IMG-20230428-084557373.jp g" target="_blank">https://i.postimg.cc/X7b9cF3v/IMG-20230428-084557373.jp g"/> [/img][/url]
Anyone know for sure where it's from? Grip2 damper if that helps.
Cheers.
Posted : 28/04/2023 12:31 pm
Sits under the red rebound adjuster, between the high and low speed.
Posted : 28/04/2023 12:33 pm
Cheers!
Really don't want to have bits left over when putting forks back together...
Posted : 28/04/2023 1:54 pm
Step 45
Install the larger High-Speed Rebound (HSR) knob with its thinner rim facing toward the bottom nut. Coat the wave spring with a thin film of Slick Honey then install the smaller Low-Speed Rebound (LSR) knob with the wave spring between the two knobs. Put slight pressure on the LSR knob so that there is a bit of preload on the wave spring. Align the set screw with the flat on the LSR needle then tighten clockwise to 8 in-lb (0.9 Nm) torque with a 2mm hex wrench. Test that both knobs turn freely without binding.
Posted : 28/04/2023 4:39 pm
