Fox 36 float tech a...
[Closed] Fox 36 float tech advice
4 Users
Hi
I have altered my 36 float fork from 160 to 140 travel. Should I have put less float fluid in the air chamber
Posted : 05/09/2013 9:21 pm
Anyone?
Posted : 06/09/2013 6:13 am
Give loco or mojo a call.
Posted : 06/09/2013 6:33 am
At risk of being accused of stating the bleeding obvious, have you read the specs in the manual? It's all in there...
Posted : 06/09/2013 7:25 am
Fox's online instructions state that you use the same amount of fox fluid in the air chamber even if you change the amount of travel. Problem is that the fork is much more progressive in 140mm mode than 160mm anddoesn't achieve as much travel with the correct sag. Ill call mojo.
Posted : 06/09/2013 7:31 am
Emailed Fox about the same issue when I lowered mine, and yeah use the same amount of fluid
Posted : 06/09/2013 8:05 am
Ok, cheers spuddle
Posted : 06/09/2013 9:04 am
