Fox 36, 29 er, 2022...
[Closed] Fox 36, 29 er, 2022, 160mm Grip 2, setup tips ?
4 Users
Have just had the LBS do a nice fork, stem and bar upgrade on my nearly 2 yr old Levo SL and now have this shiny new Fox 36 😁. I have setup to the pressures and compression, rebound etc as per the manual for my 13 stone self and have pavement tested. Hoping for a proper ride tomorrow…
So, any setup tips, it has 1 token as standard and I’m at 83 psi air.
It replaces a 34 Float 29, 150mm, Grip, 51mm offset, which is having a service in the shop and will be getting sold soon.
Posted : 07/05/2022 5:06 pm
Same fork i have on my spectral and found a couple of clicks + in the hsc worked for me as it was diving through travel at times. Similar set up to your air pressure as well.
Posted : 07/05/2022 5:20 pm
 poah
don't expect much adjustment range from the damper.
Posted : 07/05/2022 5:21 pm
Good to know, thanks
Posted : 07/05/2022 5:42 pm
90kg here, running slightly over recommended pressure (can’t remember exactly what) but with token removed. Both compression wide open and a click less on both rebound dials.
Not a big jumper and not hitting big drops. Do a lot of woodsy stuff, so value a supple fork over roots and ruts, but that returns quickly. Stock settings felt a bit slow over this kind of stuff.
Had it since Feb and my first Fox fork for 7 years. Not as nice as my Lyrik at slower speeds but feels better the faster you go. Feels much more composed at my limits.
Posted : 07/05/2022 10:29 pm
