Fox 34 2017 tyre cl...
[Closed] Fox 34 2017 tyre clearance?
7 Users
27.5"
Anyone know if a 2.6" Minion will fit?
Posted : 03/07/2018 7:20 am
I had some 2018 versions which I believe had the same chassis (Boost ones mind) and they had plenty of room.
Posted : 03/07/2018 11:28 am
If it's Boost then yes
Posted : 03/07/2018 11:32 am
I'm running a 4" tyre on a 26" rim with good clearance on a Boost 2017 34.
Posted : 03/07/2018 11:33 am
Yes sorry should have said Boost version
Posted : 03/07/2018 11:51 am
I've run a 3'' Minion on a 40mm rim in a fox 34, it's tight but okay, a 2.5 or 2.6 is perfect.
Posted : 03/07/2018 12:37 pm
Probably no help but a 27.5x3.25 on a 40mm internal rim fits the boost 29 version of the forks with about 5mm clearance either side
Posted : 03/07/2018 8:19 pm
