Fox 32 Float Perfor...
[Closed] Fox 32 Float Performance FIT 120mm (Canyon) oil levels
2 Users
Want to do a lower leg service and seal change on these forks that came on a Canyon, but damned if I can find them on the baffling Fox website, closest I can find is number 29 at http://service.foxracingshox.com/consumers/Content/Service/oil_volumes.htm but I don't know if the F120 is same as FLOAT.
Anyone know if 30ml in each leg will do the trick? And does it have to be 10wt, I have 15wt for my RS forks, shirley it can't make a huge difference?
Now, to find a service guide that roughly relates to these forks...
Posted : 31/07/2013 12:12 pm
 LoCo
30 per leg of 10wt
Posted : 31/07/2013 12:17 pm
Cheers Simon, I will be phoning you in the next day or two for some seals and oil then
Posted : 31/07/2013 1:03 pm
