I guess you've all seen the fox recall on the 2013 evolution forks
[url= http://singletrackmag.com/wp-content/uploads/2013/10/fox-recalling-some-2013-32-and-34-evolution-forks/ ]http://singletrackmag.com/wp-content/uploads/2013/10/fox-recalling-some-2013-32-and-34-evolution-forks/[/url]
It turns out the forks on my girlfriends Commencal are in the recall, I've checked the serial number online and it gives you a reference code to speed up replacement of the damper. However, it doesn't say what do to do next? unless I've missed the obvious? I'm assuming I need to send the fork to Mojo?
Anyone else got to send forks back?
My fork and shock's serial number are not recognised....however there is no difference between CT or D all a bit squishy.... Took it to my LBS and they're off to Mojo this week...Fox can't afford to balls this up any further
IMHO
Phone Mojo and they will arrange collection
I had trouble seeing the 5,8,0, if it is the first number then it will be a zero
Btw, heard about a few of these forks failing in the alps this summer
Cheers for the clarification... I was left a little confused as one place said contact Mojo and another said no need to contact Mojo.
First job for tomorrow morning then.
